charzree
I have two FCU's in the same room. Can these two FCU's (3 phase) be fed from same cable from the panel located in the another room? Is it acceptable as per codes? or do I need to run separate cables?
Discuss Three phase - serial connection in the UK Electrical Forum area at ElectriciansForums.net
What exactly do you mean FCU 3phase?I have two FCU's in the same room. Can these two FCU's (3 phase) be fed from same cable from the panel located in the another room? Is it acceptable as per codes? or do I need to run separate cables?
I’m thinking a switchfuse?What exactly do you mean FCU 3phase?
Possible I suppose, but I would like to be sure what the OP means, I'm like that as you know.I’m thinking a switchfuse?
In the UK when people speak of an FCU it usually means a single phase switch plate usually used to connect single phase appliances, this is where the confusion has arisen.I mean the three core (Multicore) Power cable running from the panel to the FCU 1 and then from Junction box / Switch Isolator, another cable will be connected to FCU2
Reply to Three phase - serial connection in the UK Electrical Forum area at ElectriciansForums.net
