W
woneye69
hello everyone! On a new installation (a poultry house) one circuit supplies a control panel, which controls fans(there are 29 over three rows all 3ph) a misting system(basicaly just a 3ph pump) and the heaters (6 all 1ph). should i be filling out a complete new form for this panel or is there some way i could record all the diffrent values on the original form?
you should fill in a different cert for any peice of the installation which comes from a new protective device.
Ie. a cert for the circuit that supplies your panel. a cert for the circuits from that point. if your mister is a self contained unit that contains a breaker for that pump, (ive used them before and the ones i used did) then you have to fill in cert for that also.
three phase testing a circuit with a crontroll panel
woneye69,
johnboy6083,
