Hi All
Could anyone confirm the following:
A 3 phase transformer has delta wound primaries and star wound secondries. The turns ratio is 1:1. If 415v is applied to the primary, will the secondary voltage be 240v?
I think it will because the secondary output voltage will be: primary line voltage divided by root 3
Is this correct?
Is this correct?
