L
Lofty
Hi Guys,
Don'tdo that much with 3 phase but have an issue at the moment.
Had a 3p motor burn out on a farm elevator. Anyway motor was returned to the reconditioner as it was only about 7 months old and it's NOT in constant use.
Reconditioner said 'It's a right mess inside looks like you've lost a phase'.
The elevator is controlled via the control panel of a potatoe grader and this runs 3 or 4 elevators depending on what they want.
Another elevator was connected to the panel on another outlet ( the original had tripped) and runs fine.
So new motor arrived and before running it I got the following readings from the 'faulty' outlet....
Phase - Phase ( L1-L2 , L2-L3 , etc.) 393v or 394v and all showing a righthand rotation. The query is this though....
L1 - Earth 255v
L2 - Earth 212v and
L3 - Earth 212v
Did the test several times and always L1 to Earth was 255v
Is this the norm for one to be that much higher ?
Thanks in advance.
Lofty.
L1 - Earth 255v
L2 - Earth 212v and
L3 - Earth 212v
Thanks in advance.
Lofty.
