Thyratron power supply | on ElectriciansForums
Discuss Thyratron power supply in the UK Electrical Forum area at ElectriciansForums.net
pc1966
Dundee
A friend of mine pointed me to this video on testing a 1930's desing of regulated DC power supply and I thought of @Lucien Nunes and the other folks here immediately! So if you have a spare 20 min you might find it interesting:
Nice. Before thyristors there were thyratrons - voltage controlled diodes:
Thyratron : Circuit Diagram, Working Principle and Its Applications - https://www.elprocus.com/thyratron-working-and-its-applications/
[ElectriciansForums.net] Thyratron power supply
Radar Modulator - Radartutorial - https://www.radartutorial.eu/08.transmitters/Radar%20Modulator.en.html
In my earlier life a thyratron would be found in a radar modulator to provide a high voltage pulse of fixed duration - determined by the inductor/capacitor pulse forming network - to a magnetron which in turn produced high power pulse of microwave energy. If I remember correctly one E/F radar charged the pulse forming network to 8kV.
This was not the highest voltage. Inside a D band radar set the PFN operated at 35kV which pulsed a klystron - but technology had moved on and it used thyristors in a sealed tank of oil to do the switching.
We have two devices that use thyratrons, a lighting dimmer with five pairs and a spot-welder.
However my favourite gasfilled, grid controlled device is not a thytratron. It's polyphase, heaterless and bulbous:
Reply to Thyratron power supply in the UK Electrical Forum area at ElectriciansForums.net
Thanks for that advice. I don't know the MV capacity locally, though there are lots of wind farms several miles away so generation is not such a...
Take your photo on phone. Screenshot it to replicate it, then crop out the excess screen. Brings the image file down to a reasonable size. Was...
Your electrician can't do it. The dno has to do it, and it will be entirely at your expense. Be careful moving anything as mentioned above older...
The contacts are pushed open by a cam as the shaft is turned so they operate quite slowly. That's fine on AC as any arc is self-extinguishing at...
