L
LeighSawczyn
So I have to use 16mm SWA to provide power to a proposed apartment conversion. As there is no gas then the supply has to be adequate for shower, cooker, ring, water heater, oil filled radiators, etc.
The origin of the supply is more than adequate for the load, my main problem is how do I break the 16mm SWA out of the house at the origin of the supply and tidily bend it down the wall with such a tight 90° radii? I don't like the thought of the cable coming out of the wall then bending back on itself like a shepherds crook and I'm not too keen on an adaptable box with the cable being terminated into a henley block or similar inside, having said that it may be the only feasible way to get the 90° turn I need in a short space unless you have any other ideas. Thanks in advance
