Tightening galvanised pipe and fittings plumbing advice | on ElectriciansForums
Discuss Tightening galvanised pipe and fittings plumbing advice in the Plumbers Forums area at ElectriciansForums.net
Tightening galvanised pipe and fittings I have a threaded galvanised tube between 2 T-pieces. I can’t screw the t-pieces onto the tube - they’re already sealed to the spur. So the only way I can screw the pipe between them is to screw it all the way into one side then screw it halfway into the other (by unscrewing from the first end) . So neither is tight.
How do I seal this? I can see that I can use enough PTFE tape on the 2nd end but by un tightening the first end halfway won’t I destroy that seal?
What’s the proper way to do this? I have three tubes in my setup to do this to.
Tightening galvanised pipe and fittings to read more on the original thread at Plumbing Advice
See also UK Plumbing Advice for all UK plumbing advice needs.
Reply to Tightening galvanised pipe and fittings plumbing advice in the Plumbers Forums area at ElectriciansForums.net
T
What plumbing tape is recommended for a copper waste water pipe Hi there, We have a leaking waste water pipe which our washing machine, boiler and...
Tellie
T
A
Blocked pipe Hi, ive got a blocked pipe from my basin/washing machine. Its old style pipe, the blockage is about half way down the pipe . Its old...
Andrew74
A
