Tile on tile Discussion Thread | on ElectriciansForums
  • Thread starter Paul J
  • Start date
  • Replies 0
  • Views 130
Discuss Tile on tile Discussion Thread in the Tilers Forums - UK Tiling Forum. area at ElectriciansForums.net
Tile on tile
Hi. Hoping you al. Can help me.
I have an issue where I had a bathroom built and a shower installed. The shower is tiled floor to ceiling on three walls with a shower screen on the 4th side.
I had issues with the tiles that the fitter installed ( he has since disappeared so I can’t go to him to resolve ) and I thought I’d try to do the bits myself.
Anyway The grouting in the tiles is weak and in places has gone leaving gaps between the tiles. I have dug out as much as I can and regrouted Not my issue is the alcove he built and tiled The base of the shelf is angled backwards leaving water pooling at the rear of the shelf. I think I have a solution without ripping all the tiles out I was going to lay another cut tile ( with an insert to raise the back so the water drains out ) but my question is. Can I tile on tile in the recess or do I have to prep the base tile and if I do need to prep it could anyone let me know how and with what These are very glossy porcelain tiles
Tile on tile for the Original Article on Tiling Advice Forum
Reply to Tile on tile Discussion Thread in the Tilers Forums - UK Tiling Forum. area at ElectriciansForums.net
Large Format Tiles / Score and snap I need advice on score and snap cutting of large porcelain tiles, lets say, over 1000 mm long and at least...
SergeTiler
P
Leveling uneven kitchen walls for porcelain tiling I will be tiling with 60*30 procelain tiles. They weight about 3.57kg each which is about...
poiupp
P
