tiling | on ElectriciansForums
Discuss tiling in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
I
iamelectric
i am going to tile my kitchen floor , their is linoleum down now can i just leave it down and tile over the top of it , will the adhesive take to it?
Rip the lino up. Then prime the sub base before tiling. If you have a screed sub base use a regular adhesive, avoid rapid set if you cant tile quick. If your sub base is green chipboard you need to use flexible adhesive and if you have regular floorboards you need to either overboard in ply or take the boards up and lay green board or 25mm ply and again use flexible adhesive and grout.
I tiled my mothers bathroom, all I can say is messy if first time, but I've learnt a few tricks since then for next time.
Remember to measure so you don't end up with 10mm cutting down a side . Apply too tile and stick each one by one instead of covering floor.
I spread adhesive over the floor and back butter the tiles which makes for a good grab
Take the Lino up, believe me you WILL regret tiling on top of lino, it's a no brain-er really
Reply to tiling in the Electricians Chat - Off Topic Chat area at ElectriciansForums.net
Best Tile Adhesive for Large Format Tiles XXL Tile 1m x 3m Porcelain Glass Tile etc Just thought i'd get a poll on the go :) What is the Best...
Which is the Best Tile Adhesive for Floor Tiles? Which Tile Adhesive Did You Use Most During 2010? Please vote on the Poll. All answers can be...
DHTiling
