time clock | on ElectriciansForums
Discuss time clock in the UK Electrical Forum area at ElectriciansForums.net
salford
Hi,I have fitted a timeclock throgh a contactor for some outside lights,and when I press the over ride on the time clock the lights only come on for a few seconds,then the contactor kicks,yet when I press from auto to over ride at the switch, they stay on, is this normal.I have read the instructions back to front but no info about it on there,Anyone got any ideas?
What do you mean by the contactor 'kicks'?
Which sangamo digital timeswitch is it? I've had trouble in the past with the override on the digital round pattern timeswitch, the button on the side of the housing was sticking and the timeswitch would register a double press every time you pushed it.
I meant it comes on for a few seconds then switches back off,Its brand new so would think its not sticking.I can't see it being a fault on the wiring otherwise it wouldn't stay on when I use the main over ride switch or would it only pick up the fault when you use the timeclock over ride,is there a failsafe built into it? Its got me baffled .its a sangamo digital 854,and thanks for your reply
Use a test lamp and monitor the output from the time switch to the contactor under both conditions.
Test lamp or analog meter. You won’t see a pulse on one of those new fangled digital test meter thingies.
Can you clarify what you mean by the main override switch? As far as I can remember e854 only has one override button, the one on the outside of the base.
It is this override button which I had trouble with in the past, it was registering a double press of the button so only energising the output for a second.
That override button should switch on the output for 2 hours.
Does the timeswitch operate correctly otherwise?
There is a switch with off, auto and over ride on it, the over ride on the switch makes the lights stay on no problem,but when I tested the over ride switch on the clock itself they only stayed on for a few seconds,so was wondering if that was normal.If they are staying on from the switch on the wall I am presuming there is no wiring fault and it is just something to do with the timeclock itself. I have double checked everything and can't see anything wrong.
[automerge]1599389794[/automerge]
i turned it off because I dont want to risk burning out a ÂŁ170 time clock until I am sure its normal
Is there any other control on the circuit for example a photocell?
Do you know what,I am sure I saw one outside the garage but thought it was for the lights on the garage wall.
[automerge]1599390742[/automerge]
I think you have just cracked it,will check its on the same circuit tomorrow. Thanks a lot,I really appreciate the advice
Reply to time clock in the UK Electrical Forum area at ElectriciansForums.net
Is it a retaining wall? If so I'm of the opinion penetrating damp is almost impossible to avoid. Make a channel underneath for runoff and slosh...
Thank you, both. Seems like common sense may have prevailed, and the fellow is indeed going for one of the modern mirrors you mentioned...
