Time Delay/Lag Switch Issue | on ElectriciansForums
Discuss Time Delay/Lag Switch Issue in the Lighting Forum area at ElectriciansForums.net
Warwickshire
Hello all!
I work in maintenance and one of the properties I maintain has a issue with the timer switches in the corridor. They don’t turn off when you press any other switch other than the master switch and it seems to function normally. However I did notice that when you press a two of the slave switches the certain lights would flicker in a certain location. Any rough ideas on what it could be would be appreciated.
Many thanks!
Also,what type of light fittings,and system function,or how it should function.
Reply to Time Delay/Lag Switch Issue in the Lighting Forum area at ElectriciansForums.net
Hello What was the conclusion of your problem?
I doubt the terminals in those are suitable for 4mm, more likely designed for 1.5mm as they are limited to 16A. You could use the time switch to...
davesparks
