Time Switch | on ElectriciansForums
Discuss Time Switch in the Australia area at ElectriciansForums.net
Den
I need a time delay switch to turn off after 1 hour
this is to connect two terminals on a heat pump 47v low power I need a switch that can disconect these wires after the one hour period
I was thinking a 230v switch and relay to disconect the low voltage terminals where can I get one
Are these even avilable
Thanks Den
Reply to Time Switch in the Australia area at ElectriciansForums.net
I'm just trying to understand the current your suggested relay needs to handle. Surely the above is not the running current of the lamp? That...
This contactor you suggested unfortunately only has two NO switches rather than 1 NC and 1 NO required for the CR3 current sensing bypass...
