Timeclock help | on ElectriciansForums
Discuss Timeclock help in the Electrical Tools and Products area at ElectriciansForums.net
H
Hogshaw
I am trying to source a timer I need the time to come on at 8.00am for 1 second this will trigger a contactor and I need the timer till come on again at 9.am for a split second to kill the contactor has anyone ever come across these?? If so would it be possible till post a link. Thanks
you can set those timers to any amount of time you want, we built a photography film developer out of an old record player connected to one of those, it would spin the disk for a few seconds then stop then respin etc etc, so it should do what you require it to. A trip to your local maplins for a chat with the staff there may also help.
You could use a din rail impulse contactor/relay and a din rail pulsed timeswitch....each time the impulse contactor get a 1 sec pulse from the timeswitch, it changes state, ie 8am 1 sec pulse, impulse contact stays on until another 1 sec pulse is recieved, as so on.....you over ride switch will be breaking feed from impulse contactor, to main operating contactor.
Reply to Timeclock help in the Electrical Tools and Products area at ElectriciansForums.net
Yet another update: I believe what EDF have done is moved me from an Economy 9 to an Economy 7. I've just emailed them to ask if they can switch...
M
This old thread has a short video which seems to reinforce your description (see post #2) but doesn't help much...
