timeclock in house,boiler in garage | on ElectriciansForums
Discuss timeclock in house,boiler in garage in the Central Heating Systems area at ElectriciansForums.net
C
collie
Hi guys,
I am needing advice here. Currently wiring my own house and as the header says the timeclock is in a room in the house. Boiler and pump are located approx 45m away(cable run distance) in the garage. I had planned on running from the wiring control center to them in 5 core 0.75 flex but have been advised that its only good for 3/4 meter runs? Anything more and it should be 2x T+E or 5 core Hytuff? Can't see any info in the BRB to help me understand why.
thanks for your help
Eugene
Reply to timeclock in house,boiler in garage in the Central Heating Systems area at ElectriciansForums.net
I think that's the point I was trying to illustrate. If volt free contacts on a device on one supply are switching mains voltage coming from...
I fitted a Mem MR30 Pod and MCB, about ÂŁ75 for both.
