Timeclock to Nest System | on ElectriciansForums
Discuss Timeclock to Nest System in the Central Heating Systems area at ElectriciansForums.net
Point2
Home
Happy Christmas/Holidays to all.
Want to replace the below timeclock with a Nest. System uses an oil boiler and an immersion heater for the water. Heating fully controlled by existing timeclock, no thermostats.
Current timeclock:
https://i.Upload the image directly to the thread.com/bhMDqdi.jpg
https://i.Upload the image directly to the thread.com/fP2KFKp.jpg
Hive Diagram:
https://i.Upload the image directly to the thread.com/Ub7aV2tl.png
Am I right in saying I will replace as follows:
https://i.Upload the image directly to the thread.com/mqcUr79.jpg
I see on another forum that you are in Ireland, so you should really consider having this installed by a Registered Electrical Contractor (REC).
Reply to Timeclock to Nest System in the Central Heating Systems area at ElectriciansForums.net
I think it was too early yes I meant 3 not 2, but great I'll give that a whirl and thanks.
That's just a standard timer switch. The 2 red wires to the timer are the switch contacts, the 2 blue wires are power to the clock. The 'orange'...
