Timer Transformer leads to cut wire? | on ElectriciansForums
Discuss Timer Transformer leads to cut wire? in the UK Electrical Forum area at ElectriciansForums.net
Ohio
[ElectriciansForums.net] Timer Transformer leads to cut wire?
Hi - you presented you header with a question mark then posted a picture, can you expand on what exactly you are asking us here.
Where is the wire that you say is cut and what function does this or did this unit perform?
Reply to Timer Transformer leads to cut wire? in the UK Electrical Forum area at ElectriciansForums.net
That doesn't make sense it is a completely new timer so needs connecting as per the instructions for this unit. Has the safety cut out on the...
Elkay 2235A-1 Energysense White 3 Wire Touch Timer 16A 240V. This is a touch timer (you don't need that bit) which also can be activated by a...
