Jumper
Given the demand for low energy lighting in new build/major extensions it seems that the LED technology leads the supporting equipment such as dimmers and timers.
The problem I have is that a client wants to put all the lights on each of four circuits on a 24/7 timer for security purposes (each timer can be switched in and out of its respective circuit). Not all of the lights in any particular circuit will be switched on when using the timer but he doesn't want to limit which, or how many, lights he chooses to use. He has had this done before when using incandescent lighting using something like the Timeguard NTT04. No problem for tungsten/halogen - these timers can manage 2.4 Kw but the limit for LED is just 100W. One of the main circuits has 35 lamps which, if they all were to use 8W LEDs and were all switched on would mean the timer handling 280W. This is mainly a retro fit so we can't easily split this circuit and use more timers.
Without getting silly with industrial timers, does anyone have any suggestions/recommendations?
