-Tinned copper cables | on ElectriciansForums
Discuss -Tinned copper cables in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Midwest
Nearly Esteemed
Oxfordshire
Did a bathroom refurb' this week, where the lighting circuit I worked on had tinned copper cable, not sure if that's the correct terminology.
Kept a piece of the cable, and looking at the markings, it's a BICC cable, with markings of 'Y Type' and 'H'.
I've did some quick research, and read that these cables were tinned like the old rubber cables, to prevent reaction between the rubber & copper, manufacturers carried on the process with PVC for short time?
Cable tested out okay, but saw some unrelated 'DIY' bodges and the CU's a bit of a mess, with RCD main switch for the whole install.
I don't do EICR's, but when I do Minor Works, I was going to suggest to the customer to have one done. Any idea of age of cables?
I think tinned copper was around the 70s briefly.
Perhaps the oldies on here installed it :)
I'm gonna call you a cheeky monkey, I was around in the 70's :(. Don't recall seeing it, do remember the dreaded aluminium cables, in the mid to late 70's, along with petrol coupons for my Fizzy Mop!
I was born in the 80s so have no idea about fizzy mop??
I've encountered tinned stranded cooper cables on a eicr and rang a technical helpline for guidance on the ccc of said cables and the guy said he had installed the stuff in the 70s but it wasn't around for long.
I could be wrong tho.
We have just finished a job that had all aluminium armoureds installed from the middle 60's iirc, how gutted myself and others where when we was cutting loads of it out and some where like 120's and 240's, is was a lot easier to move though.
That's a thought, they technically aren't SWA so would you refer to them as AWA?
nope. AWA cable has aluminium for the armour instead of steel. this is used where it is undesirable to have magnetic field currents caused by ferrous armour.
They were around for ages - from the beginning of plastic insulation in the 1950s until metrication. Most likely late 50's to late 60's. I can't believe you've never seen PVC insulated 7/.029? Although as Pete says if this is solid core tinned copper it must be 1/.044 which is bang on 1mm². Anything larger would be stranded, or not tinned copper.
Solid tinned copper have have not seen, stranded tinned copper yes. You sure it isn't copper clad aluminium, BICC branding hints at this. Does it break easily.
This cables in question had Ali armouring ;) and weren't used for any perticular reason like EMF issues.
Iirc DNO also like to use AWA as that's the only time I've installed in myself.
Reply to -Tinned copper cables in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
