Hi guys does anyone have any tips for getting a 40-50m length of 10mm earthing conductor through a run of 20mm Kopex? Many Thanks
Discuss Tips on getting cable through kopex in the Commercial Electrical Advice area at ElectriciansForums.net
Small plastic bag on the end of the string can help.Hoover taped on to one end. And bit of string the other and suck it through the kopex. Not sure if it would work over that distance though.
why would you put SWA in thats the begging question .Hi guys does anyone have any tips for getting a 40-50m length of 10mm earthing conductor through a run of 20mm
who mentioned SWA?why would you put SWA in thats the begging question .
You can purchase a 30 mt coil if required, they also do a split versionThanks for the tips and info, people. Little spark it seems your correct they only come in 10m packs by the looks of it, looks like there will be a couple of boxes along the way
must of miss readied it ,ooops. I was just about to delete it ,but the money run out like a meter .why would you put SWA in thats the begging question
Reply to Tips on getting cable through kopex in the Commercial Electrical Advice area at ElectriciansForums.net
