tips on TT systems | on ElectriciansForums
Discuss tips on TT systems in the Australia area at ElectriciansForums.net
Hi guys I done a install today and the system was a TT. My 1st TT
can you guys give me some tips on what to expect when testing.
I only did a socket change n light switch change
things to look out for ie zs readings ze readings electrode testing ( how to ) etc
many thanks jon
Reply to tips on TT systems in the Australia area at ElectriciansForums.net
Generally speaking local earthing will rarely be below a couple of ohms, so in parallel with a TN-S sub-ohm value will make little difference...
As previously posted, almost certainly due to differences in readings obtsined with high and low current measurements on the meter, low current...
OLDBOY
O
