TN-C or TN-C-S | on ElectriciansForums
Discuss TN-C or TN-C-S in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
T
Test Probes
Hi. Can any one clear some thing up with my schedule of test results for form? The situation is this. I'm testing a building with TN-C-S coming into the switch room. The earthing arrangement being used for the DB's coming out of the main switch gear is TN-S. When filling out the schedule of test result form, do I tick TN-C-S for the main system or TN-S for the earthing arrangement?
It's TNC-S it cannot possibly change, it is combined up until the in comer but then seperates from there, that is the definition ofTNC-s!!, it's not possible for the arrangement to change.
Don't forget your arrangent is relevant to your ZE, however post switch room it becomes ZDB and simply forms part of the R1&R2 part of your earth fault loop path .
As PME/TNC-S provides you with (for want of a better word) an ''artificial'' earthing point, that earthing arrangement will remain the same throughout the installation as a whole. The N-E connection will only be present at the at the DNO's incoming service head.
Now, is your supply to the Main Switch room coming from an on-site MV/LV distribution TX?? If it is, then you will probably looking at a TN-S earthing arrangement. What you could be looking at within the Main Switchboard, is the TX neutral earthing point!! It can get a little confusing for those that don't have larger project experience... lol!!
Hi Toni mc. I know the main switch gear and the local energy supplier have installed TN-C-S. But when the DB's are supplied with an armour cable with the armour being the earthing conductor, does this now make the DB's TN-C or is the whole system TN-C-S? ie switch room and DB's installed into the system.
Reply to TN-C or TN-C-S in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
A bit like saying plumbers makes good electricians. 🥴
N
In my first sparking era (late 90's) I was always told to run a neutral to the isolator, as the chances are whoever is using the machine will...
