TN-C-S or TN-S? | on ElectriciansForums
Discuss TN-C-S or TN-S? in the Australia area at ElectriciansForums.net
K
KevA
How do you check if installation earthing is TN-C-S or TN-S if in doubt?
Hi Kev
TN-C-S is where the electricity supplier provides a combined protective earthing & neutral conductor as part of a protective multiple earthing system
TN-S is where the electricity supplier provides a protective earthing conductor (usually the metalic covering of the supply cable)that is separate from the neutral conductor.
Regards
Tony.
Hey
If the earthing system is TN-C-S then there should be a sticker on the cut out saying - Protective Multiple Earthing or PME.
This is not always the case. We have been to numerous properties in our line of work, where there is no main earthing conductor and it looks like TN_C_S system, however there is nothing actually there to say it is.
Reply to TN-C-S or TN-S? in the Australia area at ElectriciansForums.net
A bit like saying plumbers makes good electricians. 🥴
N
In my first sparking era (late 90's) I was always told to run a neutral to the isolator, as the chances are whoever is using the machine will...
