- Joined
- Aug 15, 2011
- Messages
- 1
- Reaction score
- 0
Visited a house last week to correct a supplier fitted RCD in the tails that they had wired incorrectly. Supply tails on wrong side of RCD. Current supply is TT but post in garden indicates that PME supply is available. Place needs a 17th board and total rewire which will be done in Nov but meter needs moving for builders to remove wall 1st.
I suggested that when they have meter moved that they request upgrade to the PME supply (the TT rod is burried under a concrete path and has a relatively high ohms reading).
They have been told by supply company (SWEB) that they cannot have PME as they have an overhead supply from the post, even though the post is marked PME and all supplies from it are overhead. They went on to say I was passing the buck as I should fit the PME earth conductor to their kit!!!!!!:dozey:
Question has anyone come accross issues with having PME supply on overhead cables?? Or been told to access the Supply companies kit to do it themselves.
Tom
Tom
