TN-S Earth Clamp | on ElectriciansForums
Discuss TN-S Earth Clamp in the Australia area at ElectriciansForums.net
R
revolt3k
Need a new TN-S Earth Clamp, where will stock them?
My local supplier doesnt and only stocks gen earth clamps for copper pipes etc
be very carefull if you are going to renew the suppliers clamp as if you tighten to much you can short the line and neutral as the insulation is very brittle
Its the electricity suppliers responsibility to provide you with an adequate earth,( unless you are TT.)
get them to sort it.
if you overtighten and cause damage,:) it will cost
Not sure whether they have a legal responsibilty to provide an Earthing facility anymore.....although if requested they will usually oblige..............but only in their own time !
It is correct that the Standard type earth bonding clamp is not suitable for attaching to lead...be it a cable or a pipe although we have all seen it done many many times :D
spark1
spark1
If they provide an earth connection TNS or TNCS they have a responsibility to maintain it.
951 bonding clamps MUST NOT be used, as there is a danger that they could crush the internal conductors and cause a short.
Yes Jason I agree "If they have provided it originally"
Incidentally in spite of it conravening The B.S. stipulation for its use.DNOs have been known to use them on the incomers lead shaeath themselves....Not recommended at all I know, but they work to their own regs and are certainly not bound to comply with bs 7671,.....one rule for them and another for us mere mortals !
spark1
Its their equipment, their attitude can be measured by the comments posted
Its my bike, I will ride it as I see fit ,but if you dare touch my bike then all hell will break loose because I am the only one who knows how to do so :)
Reply to TN-S Earth Clamp in the Australia area at ElectriciansForums.net
If there's no main switch on the CU, then the RCD is doubling up as the main switch and everything is protected by it. If there is a main switch...
N
In my first sparking era (late 90's) I was always told to run a neutral to the isolator, as the chances are whoever is using the machine will...
