TN-S supply 4.2ohms, this is the solution from the DNO! | on ElectriciansForums
Discuss TN-S supply 4.2ohms, this is the solution from the DNO! in the UK Electrical Forum area at ElectriciansForums.net
G
GaryM
I recorded a Ze on a TN-S supply as 4.2ohms. Consumer unit is an all insulation Wylex twin RCD unit.
I spoke to the landlord of the property which was currently empty (now occupied) and told him he needs to contact the DNO with regards to the high Ze.
They came to site and this was the result! Essentially it looks like they're treating the high Ze with an RCD though all circuits are protected by 30mA RCD's.
I've asked the landlord to contact them and ask, in writing, for their reasoning behind what they've done and when they're going to return to maintain the earth that they're responsible for.
Also why we couldn't get away with leaving an enclosure flapping in the wind, two circular conductors through a single stuffing gland designed for one conductor. They seem to be a law unto themselves.
[ElectriciansForums.net] TN-S supply 4.2ohms, this is the solution from the DNO!
I would imagine this is a short term fix until they resolve the high ZE.
Makes you wonder.
I have a friend in the DNO and I cant see him leaving it hanging like that it would of been secured to the wall and sealed with it being left looking professional!
I put money on that its repaired before you get anything back in writing!
Reply to TN-S supply 4.2ohms, this is the solution from the DNO! in the UK Electrical Forum area at ElectriciansForums.net
