TNCS or TNS earthing arrangement? | on ElectriciansForums
Discuss TNCS or TNS earthing arrangement? in the UK Electrical Forum area at ElectriciansForums.net
London SW17
Please can someone explain if this is a TNCS or a TNS earthing arrangement because it looks like both to me. Old undersized main bonding conductor goes into the neutral block first then to an earth block that's connected to the incoming cables sheath. My rather unhelpful supervisor told me to "figure it out for myself" today, I think someone was having a bad day...
If the consumer unit is getting swapped out would you run the replacement 16mm main bond to the Neutral block and 10mm supplementary bonding to the earth block on the side of the incomer shown below, gas and water so you would have 3 supplementary bonding cables?
[ElectriciansForums.net] TNCS or TNS earthing arrangement?
Phone the Dno and ask them to upgrade.
It was TN-S, it is possible earth continuity broke down and it was changed and the existing earth braid was connected into the earth terminal to earth the cable sheath, it doesn't need upgrading it isn't uncommon.
Reply to TNCS or TNS earthing arrangement? in the UK Electrical Forum area at ElectriciansForums.net
I thought it was just a head with a link, rather than a fuse. Just strange that it can be so easy to pull it out. Different if it was a lid which...
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
