TNCS Service Head | on ElectriciansForums
Discuss TNCS Service Head in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
EddieB
Guys
Short of cutting the seal on the service fuse can you advise what the type is, the head itself is oblong about 150 x 100 with the fuse at the top with the main earth coming out of the side,is it the 88 or the 1361?
And on occasion if you were to be so naughty as to break the seal and have a look you may find the fuse has both BS88 and BS1361 written on it!
I thought you are not allowed to cut the DNO seal, is it not possible to obtain the information you require by enquiry
if you want to spend 2 hours on the phone and get nowhere, then , yes, it's theoretically possible. in real life, forget it.
Oh yes fully aware of that mate just playing devils advocate,
In the real world we have to work for a living,
However of course I would never remove a cut out
Guys
It could be a C&G question
What's in the Box ?
(a) BS 88-2
(b) BS 1361 - II
(c) BS 88-3
(d) BS 1361 - I
You've got a 25% chance....
Without pulling the fuse, I'd go for (c) personally
Reply to TNCS Service Head in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi Dave thanks for the info I revisited the premises to change a cooker switch and redone the test from the MET with MET disconnected from DB...
If the shared neutral is lost ,won`t you be getting 400v across both cottages? 2 phase US style but double the Voltage.
