tns 60amp main earth size | on ElectriciansForums
Discuss tns 60amp main earth size in the Australia area at ElectriciansForums.net
wales
looked at an installation today its a tns 60amp supply with 16amp tails & 10mm main earth.
main protective bonding of water and oil is 10mm.
take it main earth needs upgrading to 16mm?
In all liklehood it would also be fine if it was any one of the three major earthing systems in use in the UK.
Protective conductors can EITHER be calculated via the adiabatic equation (543.1.3) OR sized in accordance with 543.1.4 and table 54.7.
The latter would tell you it needs to be 16mm2 but the former would more than likely assure you that the installed 10mm2 conductor is just fine.
Protcective conductors YES bonding conductors NO
Reply to tns 60amp main earth size in the Australia area at ElectriciansForums.net
I might have got lost here, but the rotary iso is rated at 63A so 25mm armoured still wouldn't make the install satisfactory. Assuming everything...
Any metalwork connected to the MET could rise in voltage compared to true earth under an open supply neutral fault (on TN-C-S), and that would...
