TNS max Ze | on ElectriciansForums
Discuss TNS max Ze in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi guys just a quick one,
When testing a domestic install fed by a TNS supply whats the max allowed Ze? is it still 0.8ohm?
Reply to TNS max Ze in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Generally speaking local earthing will rarely be below a couple of ohms, so in parallel with a TN-S sub-ohm value will make little difference...
If the shared neutral is lost ,won`t you be getting 400v across both cottages? 2 phase US style but double the Voltage.
