P
PKBristol
From the sheath of the main incoming cable, underneath the main cut out, is a cable going to the MET block, looks original/very old, from this MET block come various earths going off to consumer units and switch fuses etc, so, TNS. However also coming from this MET block is another cable going to (or is it coming from) the neutral of the main cut out, so that's TNCS. This "TNCS" cable also looks old, same as the "TNS" cable.
Has anyone seen this before ?
Thanks, Paul.
