Discuss To Flex or not to Flex in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I'm not getting your query, flex is to be treated like any other cable if used as hard wiring thus cable calcs used or do you mean an extension lead/reel?
Think he means flex used with appliances Irons, kettles etc
The OP said 'fixed' appliances hence my query.
Think we need the OP back to expand on this before we keep the guess work up
Thank you for your response you've read it correctly , cheersI take it you are talking about flex off FCU, to fixed loads,no distance required after bs1363 fuse, the norm is 3 meters , bearing in mind csa of flex and vd.
Reply to To Flex or not to Flex in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
