Hi,
New to the forum and looking for some guidance.
During an electrical test of a property it was found to have no earth connection other than to the incoming water and gas mains.
Western Power were called to the property to confirm that PME was available but no terminal existed within the property. They advised that we should have this fitted before continuing.
Western Power will charge around ÂŁ58 to fit this terminal, however if this needs upgrading then a charge of around ÂŁ160 will be made.
I have a booking for them to do the work but should they check it is suitable with Ze of <.35 before they start the work?
If it is above .35, then the higher charge would apply to upgrade, in which case would it not be better and cheaper to upgrade/install the TT earth?
Is this a feasible option as Western Power only 'recommend' PME.
Martin
Martin
