A scenario for trainees to consider. Sub P.O. requirement is for 6 x double unswitched socket outlets fitted to the underside of the counter for tills, card reader and other IT/ electronic equipment. wiring will be surface in plastic containment. The supply for these is from al local 4 way CU, which is itself fed in SWA form a 40A MCB in the main DB, and the earthing ststem is TNC-S.
My questions are:
1. Would you fit RCD/RCBOs in the local CU?
2. Can you describe the earthing ( cpc ) arrangement for the circuit?
Reasons and reg. nos. for your answers.
My questions are:
