To torque or not to torque that is z question | Page 5 | on ElectriciansForums
Discuss To torque or not to torque that is z question in the UK Electrical Forum area at ElectriciansForums.net
Dustydazzler
Supporter
V.Nearly Esteemed
Surrey
so I need to add 1 mcb to a rather old existing mem consumers unit
I have managed to source the mcb via ‘cough’ eBay ‘cough’
But it doesn’t have the manufacture spec installation instructions manual for correct torque
Should I..
A , contact mem helpline for further information
B , wing it and guess the required torque
C , just use a normal Phillips screwdriver and let my wrist do the torquing
Thought ?
So if you cant find the torque setting are you telling me you wouldnt be able to tighten it up and would have to ask for help
No I'm not I would use my experience to see how tight the connections were, before boil in the bag Electricians and torque drivers were even thought of.
Couple of thoughts. One, never seen DNO using torque anything, just T hex and doing things tight!! You know when you tighten up, you need to wait and go back and may tighten again as the copper relaxes? Well with a torque you can definitely tighten quite a lot more. So clearly I have been over tightening (is there such a word?) for forty years. Although I have read and been told this can lead to catastrophic things (not totally sure what!) funny thing is, never happened over all that time. Agree with @The Ghost that MK sockets feel far too loose by their torque level. There is a lot more to terminating than torque alone. Such as dressing the cable and using 19 instead of 7 Strand for terminals etc.
Interesting discussion, this.
If a torque screwdriver has to be calibrated, is this an annual thing?
Kenny Ken has a point.
If the driver is used once a week, for a CU change say, that's one situation...but if you do 5 a week, should the driver be calibrated more often?
I see a difference between "mechanical" calibration and "electronic" calibration of a MFT. The former has a mechanical wear and tear element that may not be applicable to a MFT?
I expect that most of you will know just how tight is right...and i am willing to bet that even if the driver tells you it's right, if you are in any doubt you will resort to just manually checking anyway?
Maybe you all tighten the terminals, tidy up, then give them all a wee further tighten before you go home?
Better tight than slack?
No point in exhibiting a test certificate if patently the terminals are too loose, imho...the buck stops with you regardless.
I know it's not quite the same thing but we have to torque up the hv/lv connections on gen transformers and our torque wrenches have to be calibrated once a year. One thing you have to remember is to set it back to zero after use. If you don't it weakens the mechinism and it will fail its next calibration.
Reply to To torque or not to torque that is z question in the UK Electrical Forum area at ElectriciansForums.net
