Todays EICR - can you spot the mistake? | on ElectriciansForums
Discuss Todays EICR - can you spot the mistake? in the UK Electrical Forum area at ElectriciansForums.net
O
Octopus
Ok, so where do you look first when you do an EICR? I always start by looking at the CU and incoming supply:
[ElectriciansForums.net] Todays EICR - can you spot the mistake?
Suggestions?
Is there some reason some of the MCBs are switched off, like those circuits get power direct from the Henley block?
looks a possibility. the pic's a bit dark on my laptop to see clearly. but as the MCBs are 15A and 10A with 2 cables in each, looks like that's the other ends from the henley.
Reply to Todays EICR - can you spot the mistake? in the UK Electrical Forum area at ElectriciansForums.net
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
Thanks for the reply littlespark. Yes the works have been carried out. Surely it is fraudulent because basically the document is Not...
