W
wmb1973
Hi guys,
Just after opinions if you bond in 10mm to M.E.T. (same as gas/water) an external oil line. Said oil line goes from oil tank, under ground and then up into external boiler ? Flow/Return and cold feed come from inside the property.
Cheers.
Cheers.
