Too expensive? | on ElectriciansForums
Discuss Too expensive? in the Business Related area at ElectriciansForums.net
Norwich
i done a job last week for a local person:
1- carry out full test and inspection of property
2- supply & install consumer unit (providing testing all ok)
3- install new tails & bonding
4- find and repair fault with existing bathroom light, then supply and replace bathroom light
5- supply and install immersion heater timer
6- retest and certificate works
7- get call out fri morning to say no heating on at property "you haven't connected it" i was told. went there to find out that the customer had been fiddling and knocked out the RCD
8- get call out saturday to be told problem in kitchen, i hadnt trunked a peice of bonding about 2 inch tall when where it was you couldnt even get your arm to get to it, (customer concerned her dog could eat it or it could be cut with knife!!!)
9- go back outside to show her how to use the consumer unit... again... i accidently leant on the communal hall light switch which made the lights flicker as they came on to which i was then blamed for not wiring something up correctly! then also blamed for "setting" the wrong time on her economy 7 :s
gave her the bill of ÂŁ500 including call outs etc (15mile trip)
she then says too much i aint paying until you give me some comparisons of cost with other electricians!
what would you guys roughly charge for this work?
just so i can show her and get paid.
thanks for the help!!!
ÂŁ500 would only cover the CU, bonding upgrades & certification IMO.
Initial testing possibly an additional ÂŁ150-ÂŁ200.
The other bits & bobs possibly another ÂŁ50-ÂŁ100.
Call outs.....tough to say, everyone has their own idea's.
Safe to say ÂŁ500 is way too low, even for rural Wales where I am.
i gave her an estimate of ÂŁ450 for initial testing and board change and upgrade. i quoted for this last year. the property is MI cable so was annoying to change board trying to keep CPC etc. all cables were extended. i thought it was bit low, i was there two days too
More than that for me I think. ÂŁ500 would have got the CU changed, tails and bonding. Especially if all in MICC as this takes longer to joint, extend etc.
Then another ÂŁ200 ish for the other bits and bobs.... then possibly call outs on top however I am a bit of a sucker and usually end up doing these for free half the time.
Hard to say exactly without seeing job tho mate
If original quote was ÂŁ450 just for the CU etc... Then I would bill her for this works at the agreed ÂŁ450 as quoted. Then raise another invoice for the other items. This would then clearly show the extra works involved over and above the original quote.
I tend to always try and give a quote as opposed to an estimate. Then extras go on top of the quote. Estimates seem to imply in a customers eyes that they could go down.
agree. you have done work at a very reasonable price. tell her, in writing, to pay up within 14 days or you'll pass the debt to a collection company.
As above really, with the caveat that you should issue a quatation for specific work. Explain (in writing on the quotation) that if anything additional is required it will be subject to an additional quotation agreed before work takes place.
In you current position do not get comparisons, if she wanted/needed additional quotes they should be obtained by her before asking you to do the work. She didn't and it's not your problem. Give her the bill and set the clock running for collection.
She can't ask for comparisons of cost at this stage when the work is done - too late. By the sound of it she will be trying to find things you 'haven't done right' to knock more off an already very reasonable price.
Thank you for the advice. i must admit i feel ÂŁ500 is a bit close to being too cheap when i add up all the mucking about extending the cables etc. i dont think ill ever get called back for anything from her again
Call back to the house and in a polite manner rip all your nice work out and take it away its still yours at the end of the day that will wipe the grin off her face
firstly this makes my blood boil !
2ndly did you quote / estimate.yes so wahet is her problem
i would not be happy and would be warning her her i will be getting paid one way or another
If you estimated 450.00 for the original work I would have invoiced at that price and given a separate invoice for anything that was extra to the original requested work, that way the customer could only contest the extras invoice.
Either way I have no sympathy for people who want to contest the price after the work is complete rather than before work starts so at this stage in the game I would hand it over to my lawyers as soon as poss. Usually the first letter from them does the trick if it's not big businesses.
Reply to Too expensive? in the Business Related area at ElectriciansForums.net
Given that, it probably makes sense to TT the shed, unless you can be sure it doesn't act as an extraneous-conductive-part. (The SWA won't have...
Most manufacturers recommend them to be fitted. We are required to take that into account. If they had been fitted clearly it would have been...
