Torque Screwdriver..... | Page 2 | on ElectriciansForums
Discuss Torque Screwdriver..... in the UK Electrical Forum area at ElectriciansForums.net
L
LankyWill
My elbow is out of calibration and i would like to use a torque screwdriver instead, its something ive been putting off but i have finally caved.
What torque screwdriver is everyone using?
A little review would also be helpful
After looking at the extortionate prices for what is in essence a glorified screwdriver i think i might stick with the trusted technique of swear tight. I have thankfully never had a connection come loose or caused arcing due to a loose connection so im going to give it a miss.
Seems like another scam within the industry in which scare mongering is used, thanks for the input guys but im being a tight git atm.
I only bought mine because I had ended up with a credit note at a supplier due to a customer changing their mind and leaving me with a load of accessories.
What I thought was tight, turned out actually to be... not so much when I used the torque driver. Even the factory connections were quite a way off the mark.
The interchangeable blades... typically I put the large modulo driver bit on and that's it, it doesn't pretty much all the screws in the board. Print a label and stick it on the inside of the board with the torque settings and then when everythings connected, go over everything and give it a once over with the torque driver.
Reply to Torque Screwdriver..... in the UK Electrical Forum area at ElectriciansForums.net
Not used if tor real yet but it has quite a nice fine ratchet action. The forwards/backwards toggle is a bit fiddly to operate and it lacks a...
But why do they want a CU? That won't give them any more available power than they currently have. As it is a 2.5mm SWA cable it is presumably a...
davesparks
