total control | on ElectriciansForums
Discuss total control in the UK Electrical Forum area at ElectriciansForums.net
the pict
Mentor
Brodick
Just had a customer on the phone asking if I can connect up his total control heaters to its seperate consumer unit, I am going out to it this week, is this a dual tarriff set up as the term is something I thought was wet central heating, sorry if this is a bit vauge
Pict
Total control is a form of storage heating. Works from a teleswitch with 3 outputs. One for the storage heaters, one for panel heaters, immersion boost and electric shower and one for off peak immersion. The customer may be requiring you to connect the 3 tails from the heating board into the triple pole isolator switch which is sometimes left by the electricity company.
Reply to total control in the UK Electrical Forum area at ElectriciansForums.net
Hi Guys Got a job where property is set up with Honeywell evohome TRVs and controlled via central panel. They're having an extension done with...
Seen this where T&E has been fixed with a flat bend of too tight a radius.
2 3
