P
philrob
Trying to set up internet in our Summerhouse, VM Wifi not enough range so bought the AV 500 Wifi range extender. Intended to use Ethernet cable to connect into summerhouse. The garage / summerhouse are on the same circuit as the house, the adaptors pair fine inside the house. But not in the garage or summerhouse, I have an armoured cable running from the CU in the house to a CU in the garage & same again from the garage to a CU in the summerhouse. at could the reason be for no circuit in the summerhouse..driving me mad!
Phil
Phil
