Tpn | on ElectriciansForums
Tpn
  • Thread starter dave-gardiner
  • Start date
  • Replies 10
  • Views 2K
Discuss Tpn in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
dave-gardiner
Steel DB TPN - 16mm TPN singles connected to internal isolator then exit DB through grommeted hole out to a meter then return through a different hole and connect to busbar. Is this ok or should all cables exit and enter through the same hole?
For metal-clad boards make sure that the singles are NOT leaving through individual holes - you'll end up with eddy currents, unless you slit the holes to join them together and avoid eddy currents. Isn't there a piccy of this in the NIC handbook (I know there used to be!)
As previously been said all the outgoing singles (3PH + N) should go through the same hole, similar for the incoming singles, although not necessarily the same hole!
just give the students the key to the switch room. they will soon bypass the meter. problem solved
Dave
The closest BS7671 comes to that is 521.5.2 but it doesn't say anything about entry holes.
If you've got Darryle Locke's book on the 17th Edition (ECA) then there is mention in there of Eddy currents.
if all 3 phases go out through one hole and return together through a different hole it will not cause eddy currents the same as a 3phase swa through its own hole will not
Reply to Tpn in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
A suitable contactor can be used for safe isolation, but to be suitable it must be marked with the specific symbol for isolation and would have to...
I might have got lost here, but the rotary iso is rated at 63A so 25mm armoured still wouldn't make the install satisfactory. Assuming everything...
