TRAC T 45 boiler timer | on ElectriciansForums
Discuss TRAC T 45 boiler timer in the Central Heating Systems area at ElectriciansForums.net
London
Hi,
I just moved in to a flat that has a TRAC T 45 installed that controls the boiler. I already looked online on how to configure it, but couldn't find anything.
Can anyone here help me? I am attaching some pictures that I took from it.[ElectriciansForums.net] TRAC T 45 boiler timer [ElectriciansForums.net] TRAC T 45 boiler timer [ElectriciansForums.net] TRAC T 45 boiler timer
Many thanks in advance!
you slide those little tabs round the circumference in or out. one is on and the other is off. not sure which is which. you need to experiment
Thanks for the reply telectrix. This is the same information I found online, but when I went to the timer to pull/push the tabs, I couldn't find any. If you look closely to the pictures I provided, you will see that there are no such tabs.
Which brings to my question: how to setup this timer?
Reply to TRAC T 45 boiler timer in the Central Heating Systems area at ElectriciansForums.net
B
Re Condensing boiler Hi Just wondering if anyone can help? I moved into a new build several years back and have noticed that every time I empty...
Belxvs
B
can you post a picture of the heating element? if possible with the power off and the cover off.
