C
cstewart37
[FONT="]Hello all,[/FONT]
[FONT="]I have been asked to install a trace heating cable to a domestic hot water system in a school, designed to maintain the DHW at 55oC, the trace heating cables have to be taken to within 500mm of all terminal fittings & outlets (toilets, showers, classroom sink units & the main kitchen). This is the equivalent of running a flat PVC twin & earth cable surface along the surface pipe work. A 230 volt cable with no mechanical protection I am looking for regulations to quote to the site agent why this is a bad design:
[/FONT]
[FONT="]I have no problem fitting the cable to the pipe work in the attic but it’s the exposed surface runs in the public areas that I would have a problem with. [/FONT]
[FONT="]
The normal system design would be to install a pump with a return pipe back from all the outlets back to the DHW boiler.[/FONT]
[FONT="]
Regards,[/FONT]
[FONT="]CS. [/FONT]
[/FONT]
[FONT="]
[FONT="]
Regards,[/FONT]
[FONT="]CS. [/FONT]
