W
Welshsparky
Have installed 11 led downlighters to be controlled by a trailing edge dimmer switch , Inbetween the downlighters are some 0.5 watt led lights which are separately switched , when the smaller led lights are switched off the led downlighters turn dim for around a second then go back to full brightness , is the dimmer switch picking up some sort of interference ?
