Trailing Edge Dimmer Wattage question | on ElectriciansForums
Discuss Trailing Edge Dimmer Wattage question in the Lighting Forum area at ElectriciansForums.net
Salisbury
Looking at V-pro dimmers. I have 4 EN8 downlighters in a circuit which are 8 Watts. Would i be correct is assuming the total watts in circuit is 32, and therefore would require a 400w dimmer switch as i read somewhere you divide the total by 10%.
Reply to Trailing Edge Dimmer Wattage question in the Lighting Forum area at ElectriciansForums.net
Hi :) I'm currently renovating my outbuilding. My electrician has fitted 10 conduit LEDs (that support both leading and trailing edge) and x4...
Hello What was the conclusion of your problem?
