Trailing edge smart dimmer | on ElectriciansForums
Discuss Trailing edge smart dimmer in the Lighting Forum area at ElectriciansForums.net
Jhb
As the title says, I am looking for a trailing edge smart dimmer. I have gone through 3 smart dimmers already, only to read here tonight that all the dimmers I have had are leading edge dimmers. I have used a no name brand, the Ewelink smart dimmer and the Sonoff D1(which keeps turning itself on?)
This is to be used with GU10 Osram bulbs.
I have changed the bulbs from cheap Chinese ones, to more well known ones, and now to the Osram ones, only to have the same issue each time, flickering when dimmed.
I have googled trying to find trailing edge dimmers, but I can't seem to find any.
Many thanks in advance.
Sometimes also called "reverse phase" btw - although you have probably sorted by now, thought I would post in case anyone finds it useful historically. It relates to how the AC waveform (Sine wave) is modified by the dimming controller.
Reply to Trailing edge smart dimmer in the Lighting Forum area at ElectriciansForums.net
I'd start by doing the usual supply impedance tests followed by N-E voltage with the installation under some load. Also visually inspect and...
Switch by the door, pendant holder and a 100W bulb, some will remember, others weren't born yet when it went out of fashion, but this was the...
