transformer design using relay and contactors | on ElectriciansForums
Discuss transformer design using relay and contactors in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
R
Rajan Shakti
ok,lets say the transformer getting input voltages 380-400-440-480-660-690 V and out put is 230-440 v,the tappings provided for the incoming voltages but the incoming will be the same connection either it can be of any voltages,how can it be done by the use of relay and contactors for different set and range of voltages without any manual selector switch
Read more: http://www.electriciansforums.net/i...s/65547-transformer-design.html#ixzz29dZTlxdf
Reply to transformer design using relay and contactors in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
This contactor you suggested unfortunately only has two NO switches rather than 1 NC and 1 NO required for the CR3 current sensing bypass...
Hi Richard, thanks for your comment. The relay is rated 12A peak. It's also worth noting that a relay contact will perform differently depending...
    • Winner
