Discuss Transformer help after purchasing wrong items in the DIY Electrical Advice area at ElectriciansForums.net
These from tool station are very similar but a wider wattage range but with three outputs (which I do not think you need but yours has).
These from screwfix should work fine, only one output.
TLC does not have any non prewired transformers.
You could also use these from BEW or these from cp lighting.
How do you rename the links @Richard Burns?
I have a very small brain and don't know how...
Then again I haven't really looked into it..
Its an MR16 50W 12V.... This is how the electrician fitted them when we moved in
Reply to Transformer help after purchasing wrong items in the DIY Electrical Advice area at ElectriciansForums.net
