Transformer keeps blowing!!! got me stumped... | on ElectriciansForums
Discuss Transformer keeps blowing!!! got me stumped... in the UK Electrical Forum area at ElectriciansForums.net
Si-Woz-Ere
Hi there, would really appreciate any help here. I have installed two under unit kitchen lights, the long bar style with 3 lights in it with transformer concealed inside. The circuit they're on wasn't done by me. Customer also wanted dimmer on them which I installed for them. The under unit light on the right has never been a problem although it does buzz. the one on the left blew it's transformer. I replaced the unit like for like and the same thing happened again a couple of weeks later. I replaced it for three puck style lights with a seperate 20-60VA transformer. Transformer blew again a couple of weeks later. Replaced the transformer with a better one but again it's blown. The voltage it's getting is 220V though the dimmer when it's totally undimmed and the transformers being used are all dimmable. Again the one on the right has never been a problem.
Any advice?
Thanks.
The minimum output for the transformer is 20W(VA) what power is being used when the unit is fully dimmed, I bet your dropping below the minimum output threashold and blowing the transformer.
Reply to Transformer keeps blowing!!! got me stumped... in the UK Electrical Forum area at ElectriciansForums.net
Yet another update: I believe what EDF have done is moved me from an Economy 9 to an Economy 7. I've just emailed them to ask if they can switch...
My bafflement increases. I swapped the offending light with one elsewhere on the back of the house - one of those that's on a circuit of its own...
