Transformerless inverters and type B RCD's | on ElectriciansForums
Discuss Transformerless inverters and type B RCD's in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
J
JulianC
Currently looking at a 99kWp system, using 6 x SMA TriPower 15000TL transformerless inverters. I've been digging into the requirements for the elusive type B RCD and have found a handy guide from SMA here:
http://download.sma.de/smaprosa/dateien/7418/RCD-UEN103120.pdf
Page 8/11 is interesting in that it states that "all SMA inverters with transformer and all transformerless SMA inverters mentioned in the following are not capable of feeding DC residual currents to the grid due to the circuit design" - it then proceeds to list the majority of SMA's transformerless inverters.
Compare this to 712.411.3.2.1.2 which states "Where the PV converter is, by construction, not able to feed d.c. fault currents into the electrical installation, an RCD of type B.....is not required"
Happy days!
Thats interesting News. Have you installed the system yet? I am doing similar sized systems with the Tripower. Can we now say that if an RCD is not required by 7671 for fire protection on a farm say that no RCd at all of any type need installing prior to the G59/2 relay. If that is the case it will save a lot of time hunting down high current RCDs. What mounting system are you useing? and again thanks for the info
Will
Hi julian, how did your system go, i am looking at a 40kw system just now and its the metering i am trying to sort out, what meters can you use that are approved for these size of systems is it a simple case of CT's and schneider electronic kwh meters? or does it have to be landis & gyr type etc.
Also is that bang on re type B rcd's not being required?
That would save some money i have done this before at MCCB 400amps with shunt trips for agricultural and its a pain to say the least
cheers
Reply to Transformerless inverters and type B RCD's in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Protection from what? What kind of problem with the inverter is going to be helped by having an RCD on the circuit?
davesparks
